Newbie Needs Help
Chinoman
336
I'm looking to build a computer in a week or two and I need help choosing between a DFI UT nF4 Ultra-D and MSI K8N Neo4 Platinum. I probably won't overclock till later so I'm just looking on buying feature-wise.
fstime
4,382
They are both good boards exept the DFI has more overclocking features, whichever you can get cheaper.
imported_itr
900
both are very good boards. whichever you choose, you will not be dissappointed. however, i might lean a little towards the dfi, because it uses japanese capacitators.
Chinoman
336
I've heard so much about these Japanese capacitators but never knew what made them so good, what is it?
