Newbie Need Help with AMD 2400+
xTrinity
14
In WindowsXP, it only shows it as a AMD 1800+. Im trying to get it to actually run the 2GHz it is supposed to. Also, is there a way for my to use the most stable frequencies for my RAM in the EPoX 8RDA+ without using Optimal? At optimal, my ram is rated DDR200 :(
touchmyichi
1,774
sigh.... Another post of this...
Set your fsb at 133 and voila! Athlon 2400+. You can set your ram at user define and play around w/ the frequences.
Johneverd
483
Press <DEL> at start up to enter the BIOS. You can set the motherboard speed to 133 MHz there.
