feeddagoat
Hey everyone, I've been lurking on anandtech for quite a while but finally decided I need so help I couldn't get without directly asking. My problem is that my data is being split between 4 different computers and I really need way to have access to everything. Until recently memory sticks and drop box have worked but present their own problems such as getting lost or just not being big enough. The next best solution is a home server but this is where my I need help.
First of all my set up:
Main PC - AMD 6000+ x2, 4GB ram, GTX260, 320GB HDD + 1TB HDD (Main PC when working at home)
Secondary PC - AMD 5400+ x2, 4gb ram, HD4650, 250GB HDD. (Recently upgraded family PC. Main family computer and some light gaming done on it. Main use for me is the printer is connected to this.)
Laptop - Acer aspire one netbook (spend 90% of my time on this since most of my time is spent up at uni writing doing programming, research etc. Would bring it with me most places so its actually becoming my main PC
Spare PC - Dell dimension E520, Pentium D (3.2GHz I think), 2GB ram, 320GB HDD, ubuntu. (This was a family members old PC I managed to save and used it to play with ubuntu. I don't really have a use for itso was hoping to make it the basis of my server)
My plan was to use the spare PC and swap my 1TB HDD straight into it as a start. If I can get somewhere that can act as central storage, create back up of data stored on it and be used to connect the only printer to (epson DX5000 if it makes a difference) that's my main aim. What I need help with:-
1. Is it possible just to swap an HDD straight into another PC without any problems?
2. Is it worth using a pentium D as the basis of a server since they're not exactly known for being power efficient which is probably the most important thing for a server.
3. While not a primary concern atm would it be possible to to expand the server to handle TV recording duties?
4. What OS? I have access through uni to pretty much any OS for free (Apple use to be on the list but didn't see it last time I checked), so cost inst a problem.
5. What is the best way to handle backing up data? Is making a second copy the best way, or copying then compressing onto another HDD better?
While this is the easiest and cheapest way (After a PSU change since a dell one wold make me loose sleep) it leaves me with no expansion. Also the I know people always ask about raid and from research I would possibly be better avoiding it unless someone can make an argument for it. I don't have a massive budget (£250 target but can stretch to £400 if absolutely necessary) but want to do this right rather than cheaply. Any advice where to start or the best thing to do?
If you need anymore info or something cleared please ask.
