Dankk
I recently upgraded from a cheap boombox, to an actual, proper sound system for the first time (a receiver and two speakers).
These are my components:
Here is a video, to give you an idea of what it sounds like on max volume:
Even at max volume, you can't really hear it unless the room is dead silent, or your head is within a few feet of the speakers. However, I guess my question is whether or not this should even be happening at all. Is this normal?
Is it coming from the receiver itself? I notice, when the receiver is turned on and I put my head up next to it, the receiver has a "hum" of its own, probably from the electrical transformer. Not sure if this is the same thing that's coming out of my speakers, though.
Is it the speaker wires? I kinda doubt it; I took extra care in stripping the wires and attaching the banana plugs. Also, the humming noise sounds exactly the same on both speakers, so unless both speaker wires are identically faulty by coincidence, I imagine this is ruled out.
Any info is appreciated. Thanks.
- Onkyo TX-8020 stereo receiver (50w/channel)
- Onkyo SKF-4800 floor-standing speakers (pair)
