Newbie Dumb Woman needs info on Fan for D-Link Switch
Keyzzdzz
Ive wandered all over the web and stumbled into this place. From the looks of some of these posts.... Im in DEEP! So... here goes. ( No snickering....) I have a D-Link DGS 1016D switch that the fan went out in. The numbers on the fan are : T & T 4010m 12f nd8 0.16a 12vcd. I have searched for this, but all that comes up is the Switch. Like I said .. Im a Newbie, and any help on locating this fan or something compatible would be AWESOME, and I would burn candles in your honor for your help. My ignorance is so huge on this, its amusing.
Thanks
Keyzz
sm625
8,172
137
It looks like it has a 40mm fan. You're goign to have to take the fan out and look at the numbers on it and measure it. I would just start looking around my local scrapheap till I found a suitable fan with similar dimensions. Then I would make sure they bot run off the same power, probably 12V. Then I would install the new fan with the cover still off and see if it actually worked.
Motorheader
3,682
For a fan that small - probably 40mm square by 15mm/20mm thick - it is likely a black/red 2 wire fan that runs at a constant speed. Probably any quality fan with the same dimensions will do and you could put a quieter one it from a different manufacturer as long as the specs were close - anything 12v running .10a to .16a or so. One of the oldest mods/repairs to computer power supply fan has worked that way for ~20 years.
Bubbaleone
1,803
4
DGS-1016D, DGS-1024D
Physical and Environmental
AC Inputs: 100~240VAC; 12V/3.3A
Internal universal power supply
Power Consumption: 30.2 watts maximum
Fans: 1 Built-in 40 x 40 x 10 mm
Operating Temperature: 32°F ~ 104F ° (0 °C ~ 40 ºC)
Storage Temperature: 14°F ~ 158°F (-10°C ~ 70°C)
Humidity: 5% ~ 95% RH, non-condensing
Dimensions: 11.02 in. x 7.09 in. x 1.73 in. (280 mm x 180 mm x 44 mm)
Weight DGS-1024D: 1.79 kg / DGS-1016D: 1.69 kg
EMI FCC Class A, CE Class A, VCCI Class A
Safety: CSA International
Here's DigiKey's listing: 12v DC 40 x 40 x 10 mm Fan
Keyzzdzz
DAMN! look at all the responces! And all within HOURS!
I havent checked out every link yet... but the one Bubbaleone posted looks to be the EXACT one I need! ( Thanks Pookie...) This is GREAT!
" Im not worthy..." ( ....bowing low.... with eyes averted downward...)
I knew when I stumbled in here you guys could handle this simple situation. I realize this is an easy fix for you guys... but you have saved me alot of time and eyestrain. See... it pays to be ignorant... sometimes. ( snicker) Now if I can do anything for you guys.... Ya know, If you can wait... I expect to be quite good at this GEEK stuff in say... oh... mebbe 10 to 15 YEARS.. How 'bout I launch a Rocket from Coco Beach in ya'lls honor then?? ( Cape Canaveral)
Again, Thanks.
Trust me... Im sure I'll be knocking at yer door again. And next time Im not gonna make it so easy fer ya!! ROFL
Love ya and yer Purdy!
Keyzzdzz
