Hey all
i'm planning on building a system with either a duron 850 or an athlon 950. but when it comes to cooling...i know nothing
i'm planning on overclocking which ever one i get...the duron to 950 mhz and the athlon to 1.0+ ghz.
so what will i need? is a heat sink a must? or will just a fan do?
below are links to the two fans i'm thinking of buying. both are rated for durons and athlon up to 1.1ghz for the chrome orb and 1.5ghz for the super orb.
Chrome Orb
http://www.thermaltake.com/du0462.htm
Super Orb
http://www.thermaltake.com/superorb.htm
will just using these fans do? or do i need a heatsink...and then put the fan on top?
i understand that when u buy cpu's retail (in the box) they come with a heatsink. will this heatsink be fine?
thx all
Chrome Orb
Super Orb
thx all
