Hello all - thanks for the help in advanced!
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
World of Warcraft / General internet surfing / MS Office / MLB.TV HD Feeds (not sure if this is very PC heavy) / MKV Video Playback
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I would love to stay sub $1100 if possible - willing to go to 12-1300 if needed to get the job done
3. What country YOU will be buying YOUR parts from.
United States
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Would prefer to stick with an Intel chipset.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I will be carrying over keyboard/mouse/speakers...I think my monitor is dying so I'll need a new one of these
6. IF YOU have searched and/or read similar threads.
I've been reading a lot of people's posts - but most seem to be a tad beyond what range it looks like I'll need ( core i7 seems like it may be overkill for me )
7. IF YOU plan on overclocking or run the system at default speeds.
This is my first time building so I think I will be going stock - have not researched much into OC'ing.
8. WHEN do you plan to build it?
ASAP - before the end of April I would love to order the parts.
This is what I've come up with after reading around - let me know what you think (add/subtract/scrap all together etc!)
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB
GIGABYTE GA-EP45-UD3L LGA 775 Intel P45 ATX Intel Motherboard
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
LG Black 22X (CAV) DVD+R
COOLER MASTER Centurion 590
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM
PC Power & Cooling Silencer PPCS500 500W ATX12V
Dell S2309W 23 inch Widescreen Flat Panel Monitor
Windows Vista Home Premium 64
The total for these parts comes to ~$1050 before taxes. Also - are these all the parts I would need? Do I need extra fans/cables/etc.?
Thanks so much!
United States
Thanks so much!
