Newbie biker need help finding a Road Bike
Vich
Hey yall,
I want to get into road biking and im looking for a good starter bike. Nothing fancy just something i can ride, get better on etc you know the deal. What is the best bet bike to go with. A Trek? Bianchi? Looking for suggestions. Thanks
You should go to your local bike shops, as many as you can, and just start test riding 🙂 ... most important, make sure whatever shop you go with properly fits you on the bike.
What's your budget?
"Bike" has been posted on AT.
Fausto's internal alarmbot should be going off. He will be here shortly.
Originally posted by: Vich
Hey yall,
What's your budget? And you should factor in the cost of extras like a helmet, some decent shorts, frame pump, etc.
