- Oct 28, 2003
- 2,635
- 0
- 71
Tirerack and BF Goodrich site, as well as tire sidewall lists Max cold PSI under load as 80psi.
I checked my tires pressure (just one, and I had them put on yesterday in 107 deg heat) and it was at 38 psi. My driver side front tire looks a little less inflated than the passenger front (the one I tested).
Did the tire guys not inflate my tires fully?
Should I inflate them to 60 psi, does cold mean at 40 degrees outside, or just that I have not been driving.
Thank you.
Thank you.
