Newb question on Power cables.. for 7970
JBT
12,094
How do you all power your video cards with two power connectors?
My PSU provides me two cables for video cards. Each cable has an 8 pin and a 6 pin.
Right now I have one of the cables plugged in via the 8 pin and then the other cable handles the 6 pin. (This is how I've always done it)
Or would it be fine to use a single cable for the 8 pin and 6 pin....
ViRGE
Elite Member, Moderator Emeritus
167
Ideally you want to balance the load. If you have 1 card and 2 cables, then you use 1 cable for each socket. If you have 2 cards, then you use 1 cable on each card.
JBT
12,094
Got it figured as much, and thats how I've always done it, just wanted to check.
kidsafe
283
Basically any PSU that provides a cable with an 6+2pin and a 6pin PEG on one cable is saying, "Yes I can provide stable VA / wattages for an HD 7970." If it can't actually provide that, then they have no business cabling that way.
If it's a single-rail PSU, using multiple cables really isn't going to do much...It reduces the minimal risk of your cables getting too warm I suppose.
If it's a multi-rail PSU, I still don't see any real-world benefit to running a second cable unless you have the weakest multi-rail PSU ever. Most multi-rail PSUs smartly put the motherboard and CPU power on one 12V rail and the PEGs on other 12V rails.
