Newb looking for gaming pc judgment need help
gonebylaw
Hello im looking for some help I have three pre-built pcs. I need one for my work. The questions im asking are my concerns seeing as it will be my first gaming pc and my knowledge is limited.
what type of gaming do you think it can handle? Do you think it could handle adobe software such as photoshop and premire pro? Can I expand on this pc as time passes(upgrade)?(not as important just have two monitors)Do you think it would work well in a dual monitor setup?
1.http://www.newegg.com/Product/Product.aspx?Item=83-230-...
I found.
2.http://www.newegg.com/Product/Product.aspx?Item=83-230-...
3.https://www.overstock.com/12708992/product.html
My budget is 1000 if you have any other build suggestions please feel free to suggest.
(Spam removed.)
Your Newegg links are broken. The one from Overstock is a nice starter gaming setup. Dual monitors should be fine, what resolution are they? I'd upgrade it to 16gb ram though. Just about every PC can be upgraded. Have you considered building you own?
The monitors are 1080p hd and while i do want to build a computer I dont have the best knowledge of what parts I would need. I know i7 8-16gb of ram and gtx 1050 or above but i dont know the mother board the cooler or any thing else reallt
(Spam removed)
