desolation777
Alright, I am still selecting parts for my first rig and was wondering if their are any suggestions for a low-mid priced liquid cooling system.
Originally posted by: gingerstewart55
Nice choices in the parts, although I'd personally dump the Apogee GTX recommendation and get a D-Tek FuZion. A bit less restriction, and absolutely no chance of corrosion. Been seeing increasing numbers of corrosion complaints from persons purchasing the latest releases of the GTX.....almost seems like the QC on the plating process Swiftech has done is getting spotty. Why take the chance when the FuZion performs at least as well, if not slightly better, and has no aluminum?
Originally posted by: desolation777
Thanks gingerstewart ill certainly will take that into consideration. Would anyone suggest just buying a kit?
Originally posted by: PCTC2
The Apogee GTX is billet aluminum coated in zinc, something else, then the black die. Even when the black die goes, I haven't gotten any corrosion, but anyways, you can get a copper top for $38 bucks if you want.
or just this: PTS's Elite
Swiftech MCR220
D-Tek Fuzion
Laing DDC-T01s
you can pick up the nozzles from jab-tech.com
Originally posted by: manimal
What do you think that Compact kit would cool like cpu only with a quad at 1.5V?
What voltage does your Q need at 3737? The VID on both my quads are 1.2250 on the 680board and 1.2500 on the P35 board.
Those temps look better then Giselle Bunchen ^^;
Once I get some thoughts together would it be ok if I shoot you a PM ? ^^
Thx for the reply man, gonna see how I can mount the 320 inside my armour since my TJ09 doesnt have the room for it. I also just picked up that rebadged LL at the local best buy for 49 bucks with tax. That thing has a ton of space as far as I can tell. Thx for the help.
Thanks. All of this will be taken into great consideration.
Would anyone know of a cheap water cooling kit that is not crap, basically. I just need it for cpu (socket 775 wolfedale).
