New Tires and Wheel Color for my MS3
JCH13
4,981
66
My old winter tires were about ready to explode and kill everyone, so I replaced them. At the same time Black2NA and I repainted them. He mixed me a custom color that's a nice metallic and pearl orange. It looks pretty good in person and changes hue depending on the light its it, very cool. Not bad for a long night's worth of work. It's unfortunate that the tire mounting shop butchered the edges of the rims. Pardon the filthy car.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
122
I have always been a fan of odd coloured wheels when done right. I see nothing wrong with this combo.
RavenSEAL
8,661
Maybe after a wash and wax it might look better, I notice a nice layer of dirt on the surface of the car.
bbs lm-r
301
What wheels?
I've seen plenty of color combos like that, not my personal taste, but what matters is that you like it. They frack up your wheels before or after you painted em?
Any mods? I've read that atleast replacement rear MM is pretty much required for these. Upon closer look, looks a bit lowered :thumbsup:
JCH13
4,981
66
What wheels?
They're OE Tiburon wheels, $100 CL special FTW.
Wheels got messed up after painting, not going back to that garage again.
It's got a TRZ alloy steel RMM, forge BPV, Cobb TIP, Mazdaspeed CAI, ETS TMIC, a titanium shift weight I machined myself, and a short-throw-shifter I machined and welded myself. It's not lowered though.
JCH13
4,981
66
Why didn't you powdercoat them?
A couple reasons. Painting them was free and Black2NA and I could do it in a single night. I don't care about the finish being very durable. Prepping, or paying for prep, to power coat sucks, and I'd be looking at $400 to do all 4 wheels; at that point I'd buy new ones. Most importantly, though, is that the baking process required for powder coating will screw up the aluminum's temper, making the wheels weaker and more likely to fail.
alkemyst
83,769
19
FUD, most aluminum wheels are powder coated in clear from the factory. The temps should be nowhere near where it would change the aluminum's properties.
JCH13
4,981
66
I'm going to go with FM's research on this one, they contacted TireRack engineers and 949Racing engineers and learned that it was a bad idea. OEM is different because they have good process control and have designed the wheels to be strong after whatever finishing process they use. The average PC shop won't have the same process control nor will they know how it affects the wheel material's properties. It may not screw up the temper, I might be mistaken in that, but there is anecdotal evidence and experience to suggest that it's not a good idea.
MotF Bane
60,801
10
I don't know 949, but between TireRack and FM, I'll take those two sources for a lot of things.
Fenixgoon
33,419
13,039
a quick google search says powder coating is done in the 400F range. for certain aluminum alloys, that is more than enough to alter the mechanical properties.
