first of all i do not upgrade or overclock so this system has to last a minimun 3+ years and all your help and input is highly appreciated, want to get it soonish within 4 weeks, thou willing to wait a bit to see what amd will do now that 670 is out to see if they will get cut price a bit more or introduce better clocked gpus at same price.
Biggest thing is it has to last a bare minumum 3 years
keep in mind within 2 weeks of 680 release 7970 prices here in australia droped by good $150 before they were piced over $700+ now they are under $550 most of my parts will come from www.pccasegear.com only part i will buy localy is case in order to save $70 on shiping, shiping on all other parts put together will cost `$65
1. What YOUR PC will be used for. Lots of Gaming, Watching movies anime, Surfing an music listening
2. What YOUR budget is. Under $2000 AUD.
3 What country YOU will be buying YOUR parts from. Australia
4. IF YOU have a brand preference. Ivy bridge
5. If YOU intend on using any of YOUR current parts. NO.
7. IF YOU plan on overclocking or run the system at default speeds.
No Overclocking
8. What resolution will you be using? 24 inch 1080 single monitor keep the gpu minimim 3+ years and still be happy playing new and upcoming games.
9. WHEN do you plan to build it? Within the next month.
Component list v1:
No Overclocking
Component list v1:
- Corsair Carbide 400R Black Mid-Tower Case $139 here
- 2 x 120mm Case Fan for more airflow $20+
- Intel Core i5 3550 $225
- EVGA GeForce GTX 670 2gb $500 or Gigabyte Radeon HD7970 $550
- G.Skill ARES F3-1600C10D-16GAO 16GB (2x8GB) DDR3-1600 MHz (PC3-12800) $129
- CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V Modular $135
- ASRock Z77 PRO3 Motherboard $119
- CoolerMaster Hyper 212 EVO CPU Cooler $39 (intel stock coolers are crap and this one has exelent reviews on newegg)
- Western Digital Caviar Black 2TB WD2002FAEX $195 5 yr wrrnty or Western Digital VelociRaptor 1TB WD1000DHTZ $349 5 yr wrrnty (only want 1 hard drive want a fast 1 and good warranty and will get an external at later date to bk up important things)
- LG CH12LS28 12X BD-R Blu-ray DVD Combo Drive $55
- Microsoft Windows 7 Home Premium 64bit with SP1 OEM $95
