- Jan 2, 2005
- 5
- 0
- 0
I just built this system to replace my other. I put it all together and everything was secure and done properly, I made absolutely sure that nothing could go wrong. Even used a anti-shock wrist attachment. Anyway when I went to start it up there was no beep, screen was blank and the lights kept flashing on my CD drives like it kept being reset. I tried just doing barebone CPU, Memory and AGP card. That still didn't do it. I tried every configuration I could think of. I put memory in every slot and even bought a different stick of memory and figured out it's probably not the memory. The processor gets hot so I'm sure that part is functioning. Below is my configuration. I know my video works in the other system and it should be compatible with the new one. The system should boot without a video card, it just wouldn't display.
ASUS K8N-E Deluxe
AMD Athlon 64 3000+
Antec 400W Power Supply
Corsair 512Mb PC3200 DDR400 64Mb x 64 bit
NVIDIA BFG GeForce FX 5200
Maxtor 80Gb HD
The rest is really unimportant since I can't even get to the BIOS. My best conclusion is the BIOS either was improperly flashed or was somehow erased. This situation is very similar to a few others I've seen on this forum. I just want to know if others agree the BIOS is in error and that's the reason it won't work. Without memory the CD-ROM should flash but the system shouldn't load. Without the CPU the CD-ROM should NOT flash. I know this much because it works that way with my working MB. I am pretty sure that the CPU is functioning and there must be something wrong with the board.
ASUS K8N-E Deluxe
AMD Athlon 64 3000+
Maxtor 80Gb HD
