New system won't post...
StanG
194
I just put together a new system based on Soltek nForce2 MB, XP 2200+ CPU, 512MB PC2700 RAM, and MadDog GeForce4 Ti 4200 VC.
I believe I've done everything right (this is not the first time building a new system), but the darn thing won't even beep on me :(
I've tried removing all peripherals, clearing CMOS, etc... but no luck.... Could the MB be toast?
TIA
Macro2
4,874
Make sure the motherboard is grounded property. All the screws are within their approprite solder circles.
Also make sure your CPU fan is plugged properly into the motherboard. Thing won't run if the CPU fan is not detected.
Check the voltage selector and on-ff switch on the back of the PS.
Then again your PS could be dead. or...plan B.
StanG
194
Shoot... The CPU is toast... I tried my good ole' OC'd duron, and it works fine :(
DATCAT
19
I have the same problem
My new system won't post or beep or any thing
Lots of fans and lights though
biggiesmallz
Banned
Feb 1, 2003
881
Was it DOA or did you try to overclock or something. Also where did you buy it from?
