DougFrippon
Since I upgraded my computer from 2500+ barton to a 3500+ A64, I have some weird issue.
My setup is :
Windows XP SP2
Windows Media Player 10
AMD64 3500+
1gig(2x512) samsung ram
AGP8x Leadtek 6800GT (71.84)
Latest Hyperion VIA installed.
I had the same video card, same windows, everything was the same exept cpu/mobo/memory and didn't have those issue. (note: Most of those issues happen in World of Warcraft, and they only happen to ME, I can't find anyone (even people with very similar system to mine (almost exactly the same actually))
1. FRAPS : Not sure if you guys know that program: http://www.fraps.com/. It's used to record video sample of basically anything you do on your computer, but usually used for video games. I use to loose about 20% (from 30-40fps to ±25fps) when starting FRAPS, but now I loose FPS down from 60-70fps to 1-2fps!
2. My "Zoning" time are AWFUL, takes ages.
3. This issue is the one that concerns me the most.. very weird. When I alt-tab the game, and open any video file (avi/mpg/wmv) in any player (zoomplayer/wmp/divxp) my screen COMPLETLY glitch, and computer is almost 100% frozen, it takes me about 1-2min to move my mouse on the "X" and hit left click.
Apart from that.. My PCMark / Sandra / 3dmarks scores are very normal.
I tried 76.x drivers yet, and it was the same. I think it really looks like a videocard drivers issue.. maybe I should try.. 6x.xx or somthing..
Does my problem sounds familiar to anyone?
My setup is :
Windows XP SP2
AMD64 3500+
