Hello all, my new system is together and functioning but im having some trouble getting it to OC, i have a 7750 kuma on a foxconn A7DA-S. I can get it to run at 3.0Ghz but it takes +200mv to do it(1.525v), anything less and it will reset within 10 min of prime 95. I am using AMD overdrive in Vista home basic 64bit. Should i try using the bios or is amd overdrive the same thing? Its got a AC Freezer 64 pro on it and it never gets above 55c even after a hour of prime 95, it idles at 36c. Any options i should change in the bios to get a better OC? should i use ACC? thanks for the help its been a while since i have overclocked, like a long while, since my celeron 366@550
