Ok, I just bought a whole new system and got it all put together. I have had more than one problem so far, as it seems I always do when building a new system.
First I put everything together and it all worked...so it seemed....at one point when windows was just starting it went to a blue error screen and stopped. So I reboot and try again...the next time I don't get the error screen, but only because the system just shuts down...no beeping, no error lights...just shuts itself off (spooky, lol). So, I try again, this time not letting it go into the loading of windows, but instead have it go into the bios...after about 10 seconds in the bios, it shuts off again. So I pull everything apart and put it all back together again from scratch.
After starting over from scratch I run into a tottally different problem. This time my system posts, and I can go into the bios and it doesnt shut itself off (so far), but I can't try and load windows because I can't get my cd-rom to work. Here's the problem. I plug everything into the cd-rom it doesnt work. I unplug the ide cable and it lights up and will open/close...plug the ide cable back in and the light goes out and it wont open/close. I have tried two different cd-rom drives...same thing happens. I have tried three different ide cables...same thing happens. I have tried both IDE 2 and IDE 3 on the mobo, and yes...the same thing happens.
I'm about at my wits end with this new system. Any help would be appreciated. Below are my new system components.
Case: SuperAlien w/500w psu
Mobo: MSI 915P Combo-FR
Proc: Intel Pentium 4 - 540
RAM: DDR 512MB 3200 CAS 2.5 400 mhz
HardDrive: Maxtor 250 GB; PATA/133; 16mb buffer; 7200rpm
Video: ATI X700Pro 256mb PCI-E
Sound: CLabs Audigy 2 ZS
CD-Rom: Memorex 16x Dual/Double Internal DVD/RW
CD-Rom: LiteOn DVD-Rom
Speakers: Logitech X-530 5.1 Speakers
Monitor: Sharp 17" LCD
