Hey everyone,
I just put together a system (my first build, actually), and I haven't even gotten around to installing the OS and already it seems to be running pretty warm.
The specs of my system are:
CPU: Athlon XP 2500+ Barton
CPU Cooling: Spire WhisperRock IV
MB: Asus A7N8X-E Deluxe
1 Maxtor 200gb 7200 rpm SATA HD
1 ATI Rage 32MB AGP card (pulled from a 2-yr old Dell P4 system)
Case: Antech SLK3700AMB, 350W PS
Case Cooling: 1 rear stock fan
Obviously there's more pieces but these are the things relevant to my problem. Basically, all I've done is putzed around in the BIOS checking various things, and even just doing that my CPU temp is sometimes (in fact, kinda often) hitting 50c or more. After I shut down, my AGP card seems unusually hot, as does my HD ("unusually" meaning when compared to my HD/AGP after shutting down my P4 2.0g Dell- feels like a few degrees' difference). And all of this is with the case's side panel off and the case wide open, which means its actually getting more ventilation than it normally will :/
The PS, CPU, and case fans are definitely all operating (although in the BIOS only the CPU fan is showing an RPM reading - 2500 if you're keeping score). The voltage readings in the BIOS are all normal as well.
Any suggestions, or maybe something obvious that I'm doing/not doing that might help? I'd like to avoid buying a whole lot of new equipment, and I've heard a lot of good things about the stuff I'm using. I do have a slot for another case fan in the front that will almost definitely help with the HD temp.
Thanks for any suggestions!
PS- This is unrelated, but quick [and wonderfully n00btastic]: I recently managed to fry an old floppy drive (damn those old able-to-put-the-power-connector-one-pin-off-without-noticing drives), and it took a good bit of the wire with it in a horrible melt-y mess. I don't need to use that wire for anything luckily, but should I just snip it off or will it be reasonably safe to wrap the exposed wire in some electrical tape and keep it out of the way inside my case? Thanks again!
