New System... Problems?
mauaus
8
As you can see i replaced my old Athlon 64 3000+ Sct 754, memory and board to a Intel Core 2 Duo e6400 + Gigabyte DS3 and 2 gigs Wintec AMP-X DDR2 675. Everything seems really nice and fast, so i decided to try 3dmark 2006 and to my surprise my result is almost the same, if not a bit lower, the cpu tests run sluggish as they did on my A64 Performance in games seem to have improved... Am i missing something? Even the CPU tests on 3dmark 05 run slow. Is there a patch or something to add compatibility?
I am really dissapointed and happy at the same time cuz man does this thing fly!
The-Noid
3,117
4
Result will be almost the same because if you did not change video card your score is based on the 3d settings :). Look at the cpu score and see if that is faster. As for the processor running slow, it could be throttling because of heat or just on a lower multiplier of 6x.
The CPU tests are going to run incredibly slow though. Even at 4.3 ghz I get I think 12 fps or right around there.
Also if its not going fast enough overclock it some more :).
Cheers
mauaus
8
My temperatures are 40C on idle, so thats not too bad but it could be better... The multi is 8x, im gonna overclock later and gonna post some results, thanx a lot Yoxxy
mauaus
8
I just ran a benchie with my 7900gt overclocked 550 1600 and i got a pretty respectable score: 5314 3d mark 2006 so i guess everything is fine here!
