New System: Odd video problems
Mullzy
352
I just built a new system and everything is going pretty well. (IC7, 2.8C @ stock, Antec 430W TruePower). I've had it as high as 3.22 (235 FSB) without any problems CPU or memory wise (Prime95 had no problems), but then I noticed an odd video problem. I took everything back to stock but am still having the same problem (possibly to a lesser degree).
My GF4 ti4200 (this is the only old component in the system) can be downright sluggish when switching resolutions/fresh rates. I first noticed it when doing some benchmarking (3dmark2001 & 2003). Each game test would run fine, but it would take several seconds to display the informational screen between each test. The monitor would flicker a couple times as if the card was having trouble picking up the desired refresh rate.
I've also experienced the problem inside of games. Choosing a new resolution, turning AA and AF on and off (or increasing/decreasing the values) can at times take quite long to take effect. Occasionally the screen will just go black and the PC will reboot (after 15-30 seconds). When XP comes back up there will be a message about my ti4200 possibly being a problem.
These problems never occur while PLAYING a game, only when switching modes.
I noticed that my default AGP voltage is a little low (set to 1.5v but reports as 1.46v). Actually, all my voltages are a little low which I don't like. I've tried increasing the voltage to 1.55v (reports as 1.5) and it seems a little better.
When I had my system overclocked to 3.22 I tried increasing my AGP voltage to it's highest setting (1.65, reports as 1.6) but it didn't fix my problems. Will a low AGP voltage keep me from hitting high overclocks with this power supply?
Any other suggestions?
Thanks!
HippyWarlock
42
You are clocking down your PCI bus as you clock up your FSB I hope as this will bug most AGP cards.
Be carefull when increasing Volts on electronics - You can permanently damage them or weirdly, make them become dependant on a higher V. Don't ask me how, I just know it can happen.
Dunno about the hunting for a refresh rate though, sounds like a driver/OS problem
Mullzy
352
My AGP and PCI buses are locked. When overclocking I had no problems except with my video. Now that everthing is back to stock I'm still having the video problems.
My ti4200 was overclocked for about a year but I've put it back to default core/mem settings to see help eliminate a variable.
I just ran 3dmark 2001 and it completed fine (~12000 score) but there were several long pauses when switching between tests. Also, after it's done I get weird video corruption (minimize and maximize buttons on all windows are blacked out). There are ZERO artifacts or image problems during gaming or benchmarking though.
