New system not posting, Motherboard DOA?
hadareud
Hi, I'm building a new system and I'm running into a big problem, hopefully somebody here can help.
Setup:
MSI P965 Platinum
Intel E6420
550W Ebuyer Value PSU
XFX 7600GT 256mb
OCZ Special ops 2gig PC2-6400 800 RAM
Seagate Barracuda 320GB 7200.10 SataII/300
HP DVD940i 18x IDE
Antec NSK6000 case
Problem:
I installed everything (CPU, Fan/Heatsink, Ram, Graphics, HDD, DVD, USB Bracket), connected all cables, connected the system fan and finally connected the PSU.
When I power on the system the PSU powers up, the system fan starts spinning - and that's it. CPU fan does not start spinning, no error sound or anything - and no screen starting to appear. Also, the graphics card fan isn't spinning either.
The top 2 lights on the USB back bracket go red.
I tried reinstalling the CPU, disconnected all the cables except for the power switch to do a minimum start with just the CPU, Ram and Graphics - same problem.
The question is, is the Motherboard faulty or the CPU? The PSU seems to work fine, as it powers up and the system fan is spinning. Here's the PSU specs for reference:
Rail Stats:
+3.3V +5V +12V -5V -12V +5VSB
28A 35A 30A 0.5A 0.8A 2.5A
All components are brand new by the way.
I have since cleared the CMOS, but no luck either. I also tried it with the motherboard removed from the case, but same result.
Any help would be greatly appreciated! Thanks!
(I tried to search the forum but I couldn't find a similar problem).
Look in your MSI manual and tell us what that error code means.
unfortunately that seems unrelated:
Initializing Hard Drive Controller
This will initialize IDE drive and
controller.
I think I've narrowed it down to the Motherboard or PSU. There's no beep when I don't insert any components and power it up.
I found a picture of your mobo on newegg, there are three power connectors on the motherboard, do you have all three plugged in? or just the 24-pin?
good news! One of the pins on the 12v connector was bent down, I was able to fix it. I am typing this from my new system 😀
Thanks for all the advise!
