1) I just completed putting a new system together using an ASUS P4P800 Deluxe. AI have not installed the operating system yet. As far as I can tell everything is working at power up. The manual says I should hear one short beep when the logo is being displayed. I have tried reversing the speaker connector to the motherboard but that did not produce a beep. Is there reason for concern or does anyone have an idea of the problem.
2) Should I update the Bios prior to installing the OS (WinXP Pro) or after? It came with version 1005. I have read on this board that I should go to 1006 before going to the latest (1010) but I can?t find 1006. Is it really necessary or can I just go from 1005 to 1010?
3) Is it necessary to install the Via RAID driver if I am not going to use RAID. I will be using the RAID connectors on the motherboard for my hard drives but not in RAID configuration.
4) Should I run Windows Update before or after installation of the drivers?
Thanks for any help anyone can give.
