New system... Need some help please
BrentCorp
21
I just built my new system yesterday (first try at building my own). I have it working great but there are a few questions that I need some help with.
System:
T-Bird 1.33 gig 266fsb
Epox 8K7A BIOS ver. 6.00
256meg P2100 Crucial RAM
Asus V7700 Geforce 2 GTS Drivers: 12.90
12gig Harddrive
52X CD-Rom drive
etc.
1. My performance scores in 3dmark 2001 were 3350 and 7400 in 3dmark 2000... Im just wondering if this is the performace I should get, or should I have more? Is there anything I should install to get performance even better?
2. How do I know if my chip and ram are running at 266fsb.. Is there away to check?
3. I installed some USB drivers that came with the EPOX disk, but for some reason, I cannot get my optical mouse to work with USB.
Any help would be greatly appreciated.
BrentCorp
21
no, I didn't do Windows update? Would that help a lot?
I ran the program, this is what I got..
Internal clock: 1329.55 mhz
System clock: 132.96 mhz
system bus: 265. 91 mhz DDR
crzyc
670
it may help for your mouse, not to sure, i don't think i put on the usb drivers and my optical works fine but thats in w2k
you going to overclock that beast?
BrentCorp
21
Is that the performace I should get with my machine though?
I dont know how to overclock so Im not really sure if I will or not.
crzyc
670
with my vid card i get 2800 or so with 3dmark 2k1
so you did better with your card, get sisoft sandra and do some memory benchmarks
overclocking is pretty easy, what is your clock multiplier? if you lower that and up the fsb in the bios that would give you faster memory
did you write down the numbers on your processor core?
crzyc
670
go into the bios and its the option that has "voltage" in it, sorry i am not at home so i don't know exactly
but its the first or second option on the right
then enter a number, i have booted up to 156, but you should shoot for around 150, then 3dmark again =)
any higher then 1500 im not sure your chip could handle it, what hsf are you using?
BrentCorp
21
What is hsf?
I set the fsb to 140(a little paranoid about going to 150.. dont want to fry it) and I only got around 30 points higher in 3dmark2001
BrentCorp
21
when I ordered the chip, they gave me an AMD certified coolmaster fan. I dont know the exact specs of it.. pretty large heatsink though.
Duvie
16,215
those 3dmarks scores seem fine, and right in line with many. since you probably haven't tweaked much of the ram settings you may get a bit more out of it.
BrentCorp
21
well, thats good to hear that its the right score.. I love the speed Im getting, just wanted to make sure though..
