Hey peeps,
Im hoping you can help me. I've just bought an Asus motherboard along with some other parts to build a friend a PC. I am having some problems getting it all working, so was wondering if anyone acn help?!
The parts I have bought are:
AMD Athlon XP2700 333FSB 256Cache Retail Boxed Inc Heatsink & Fan
Kingston 256MB 400MHz DDR Non-ECC CL3 (3-4-4) DIMM
Asus A7V8X-X SKT A KT400 8x AGP DDR Sound/lAN/USB 2.0
Obviously there are many more parts but these are the essiential ones.
My problem is, when i turn the pc on the fan spins fine - although you can hear it slow down every two second or so - and then after about 5 seconds the whole pc turns off. Things to note are:
there are no beeps from the speaker, although it sounds like its trying to beep - a ticking noise
the PSU is fine, it powers other mobo's and if i use another power supply I have the same problem
When i plug in the pc to the mains, it turns on automatically. The power button on the case doesnt always have an affect and doesnt turn the pc off.
Its not the RAM as it does the same with no RAM inserted
As far as i know all the jumpers are set correctly, but i am open to suggestions here..
Do you think the motherboard is faulty? Should I send it back?!
Any help would be great.
Ps. I have built many pc's before and not had this problem...grrr. If you need some more info let me know and i will post it.
Muddy
Muddy
