- Dec 7, 2000
- 29
- 0
- 0
OK I finally got my Athlon 1Ghz on a Soltek Sl-75KV2-X motherboard (really good btw!! Stable as hell!) I also ordered 128mb PC133 ram, over here in the UK it was called CUBE branded..well when it arrived i looked at the chips and was supprised to see the name Infineon on it (happy as well
) I set everything up and put in my old PC100 64mb Crucial memory and the new ram (192mb total) I installed SiSoft Sandra to check everything out and i noticed a few things under the ram..here a bit of what it said.
Mircon 64mb Ram PC100 (8Mx8)- CL3 upto 125mhz, CL2 upto 100Mhz
Infineon 128Mb Ram PC133 (16Mx8)- CL3 upto133Mhz, CL2 upto 100Mhz
So does this mean at 100Mhz FSB it is classed as CAS2 ram? If so then groovy
Thanks guys
Thanks guys
