New System... Existing Hard Drive... Help
jryan25
30
I have ordered all new parts to build my new rig and I have a question I've never ran into. I am using my existing HD. Can I just hook that up and not format it? I will be keeping my same Operating System (XP Pro) and do not really want to wipe it all out, just simply plug it in and use it, does a new rig/bios allow this? Thanks.
wseyller
824
It depends on your hardware (to and from) whether it works or not. Sometimes it does many times not. It may need to reinstall tons of drivers. Then it may not run very good. Honestly it is better to reformat.
Lord Evermore
9,558
It will often just work right away, especially if it's a chipset that uses the same driver set.
You can use the Repair Install option when you run the WinXP setup disc, and it's quite effective. It will restore XP to essentially the original install, with the original drivers from the disc, all the original apps included with XP, but it leaves your data files and install applications in place, keeps their shortcuts, keeps all their registry settings. You just have to download all the Windows Updates that have come out since the version on your CD. If you can find a source for the latest version on CD (with service pack 2 included) you can also just use that with the same CD key you have now. Or you can use a program like NLite to slipstream all the updates into a new CD, before you make the transfer.
You should make backups of the system first, then before your last shutdown before the swap, uninstall all the main system drivers (chipset, CPU, sound if it's onboard, network controller, any other parts you're replacing like video). That way they're just not on the system, since they won't be needed. With newer boards you may need to at least install the network driver from the disk that came with the board, in order to be able to go download the rest of them. A better idea is to download drivers for the mainboard and all your other peripherals and burn them to a CD, so you can just go in and install them.
The Repair install will however leave whatever cruft old applications left in. Usually it's not too bad, and you can run a program like CCleaner or others to remove a lot of it from the registry, and there are lots of driver cleanup programs. A completely clean install gives you the freshest system of course, but not necessarily one that performs any better or is more stable.
jryan25
30
I reformated my HD like 3 weeks ago. There isn't much on here. Thanks for the tip and I just may make copies of everything and use nlite. THanks
SkyDiver
386
There is a better way that I used for at least two or three complete computer upgrades including new motherboard and chipset. I have the instructions at home if you are interested. Basically, you change your drivers to a bunch of plain vanilla ones (vid card set to VGA, for instance), then let the OS re-detect them upon startup with the new system.
I just re-installed a fresh WinXP for the first time since I upgraded from Win98 more than five to seven years ago. (Of course I kept my registry nice a clean, defragged, and kept spyware under control, so I never had problems with performance)
Let me know if you want it and I can post the article on how to do it.
Lord Evermore
9,558
Doing it that way is very similar to just plugging it in with no changes. When XP finds that the hardware it's trying to load drivers for is no longer there, it stops loading those drivers, and detects the new hardware. Occasionally it doesn't work right and you get a blue screen.
Just uninstalling the drivers/devices from device manager before the swap is a cleaner way of doing it, since it removes any unneeded drivers from the system.
