- Jun 7, 2004
- 48
- 0
- 0
I just put together a P4 3.2 640 (775) system with a 6800 GT in an Antec Sonata with a TreuPower 550 PS. It's an Intel 915 mobo and after installing the hardware monitor, it is reporting the following temps under load (playing games):
CPU: as high as 60
MB zones: as high as 50
How are these temps? I notice that the MB increases and decreses the speed of the CPU fan while playing games.
The Intel site states that I should set the CPU temp threshhold to 75 degrees (C) and the system as high as 60, but 50 is suggested. Obviously, I am triggering the alerts if I set it to 50.
Any feedback would be great! Oh, and the stock Antec 120mm fan is connected to the Antec PS fan-only molex. Connecting it directly to a regular molex produces a wind tunnel and doesn't seem to affect temps.
The Sonata case is in stock trim.
Rick
CPU: as high as 60
Rick
