E EffeX Senior member Apr 13, 2006 309 0 0 Jun 8, 2006 #1 Okay so I built my new rig(first timer here) and when I boot it up it beeps once then says Fatal Error System Halted. What does this mean?
F FP Diamond Member Feb 24, 2005 4,568 0 0 Jun 8, 2006 #2 Plug a set of speakers into the audio outs on the mobo. The Asus boards usually have a voice that tells you what is wrong. If that doesn't work then triple check all connections on the mobo.
JEDIYoda Lifer Jul 13, 2005 33,986 3,321 126 Jun 8, 2006 #3 http://akadad.bizland.com/rps/fse.htm http://support.dell.com/support/edocs/systems/daftshk/messages.htm http://www.hardwareanalysis.com/content/topic/46510
E EffeX Senior member Apr 13, 2006 309 0 0 Jun 8, 2006 #4 It beeps once I think and then it boots to a screen that says Chassis Intrusion Detected! Fatal Error System halted
F FP Diamond Member Feb 24, 2005 4,568 0 0 Jun 8, 2006 #5 Check the chassis/speaker/power connectors on the motherboard. One is probably off by 1 pin.
