- Oct 13, 1999
- 22,377
- 2
- 81
This is a relatively budget system build for my wife. She's a gamer, playing mostly adventure/RPG/RTS and plans to play WoW. My purpose in this system build is to make a capable gamer on a somewhat low-mid budget, with some attention to looking nice and being quiet. The parts I choose were the best choices at the time and may or may not be the same choice at any other time.
Overall the system performs very well and has met all expectations except one - it is still too noisy, though I think most people would consider it fairly quiet. I've experimented with stopping the fans and found out that two fans make the majority of the noise - PSU fan and the Arctic Cooling 3TC blowhole fan. It also has a strange glitch in that Windows takes an extraordinary amount of time to boot up. There is a delay right after the POST screen and before the Windows splash screen where the display stays dark for about two minutes - excessively long. Besides this, system performs nice and fast.
I've played with overclocking the system but the chip doesn't want to go very far - heck, my A64 2800+ will reach a higher stable clock than this 3400+. Luck of the draw. With an overclock this minimal there isn't any noticeable performance gain, so system is run at stock speeds. There is a noticeable 3D performance gain from enabling extra pipes on the video card. Four more pipes seem okay though the overclock test fails the card at any speed if they are enabled. The last four pipes cause lockup, so are indeed faulty.
Highest stable clock 208HTT 2496MHz CPU 1.50v
RAM 416MHz 2.6v 2.5/4/4/8/1T
3DMark2005 stock 2662 12 pipes 3940
In retrospect if I were to build this again, I'd probably use a Sempron 64 3400+ CPU, faster video card, quieter PSU (perhaps overpriced Sea Sonic S12 series) and a quieter blowhole fan with the grill cut out of the case.
Parts:
CASE - Lian Li PC-7BW Plus - wanted a classy but sharp look with good ventilation using 120mm fans
PSU - Fortron FSP-400GLN - wanted a modern power supply with good efficiency (rated 85%+) and 120mm fan
CPU - AMD Athlon 64 3400+ socket 754 OEM - got this from a buddy of mine for pretty cheap
MOTHERBOARD - Chaintech VNF3-250 - the ubiquitous budget socket 754 overclocker, works as advertised and doens't have Northbridge fan
HSF - Scythe Katana - "tower heatpipe" design is the rage these days and the Katana seems to be a budget no nonsense solution
RAM - Geil 2x512MB CAS 2.5 PC3200 - this is a leftover from the previous P4 2.6C dual channel system
VIDEO - Chaintech Geforce 6800LE - these are a steal at $125 new, this one can unlock to 12 pipes though some people have gotten all 16 or only 8 so YMMV
AUDIO - Chaintech AV-710 - this is a nice budget card that does good quality
HDD - Seagate 7200.7 200GB SATA - this is a leftover from the previous system
CDROM - unknown 48X - got this cheap as a system pull, I think it says IBM on it
DVDRW - Benq DW1640 - got raving reviews and is reasonably priced
MONITOR - Dell 2005FPW - yup, coupon deal for a beautiful monitor
SPEAKERS - BIC Venturi V52 - award winning and budget shielded (not needed for LCD) bookshelf speakers, some of the best I've personally listened to
MISC - Technics SA-GX170 stereo receiver - old one, decent for driving a pair of bookshelf speakers
MISC - two PC Toys rounded EIDE cables
MISC - two Cooler Master 120mm "LED Silent" fans
MISC - Antec Tri Cool 92mm fan
MISC - Arctic Cooling 3TC 80mm temperature controlled fan
MISC - 8 in 1 USB 2.0 card reader for 3½" drive bay
MISC - dual blue cold cathode light kit
MISC - Sunbeam rubber fan screws
MISC - Logisys LCD temperature and fan controller for 3½" drive bay
MISC - Cooler Master Cool VIVA heatpipe cooler for video card
PICTURES - warning for modem users, 900k of pics
Parts:
