- Apr 30, 2008
- 36
- 0
- 0
So a buddy of mine is having some troubles with his new system build.
RAM: G.SKILL 4GB PC2 8500
http://www.newegg.com/Product/...x?Item=N82E16820231166
MOBO: GIGABYTE GA-EP45-DS3L
http://www.newegg.com/Product/...x?Item=N82E16813128345
GFX CARD: VisionTek 900241 Radeon HD 4850 512MB
http://www.newegg.com/Product/...x?Item=N82E16814129112
CPU: Intel Core 2 Duo E8500 Wolfdale 3.16GHz
http://www.newegg.com/Product/...x?Item=N82E16819115036
PSU: Antec EA650 650W
http://www.newegg.com/Product/...x?Item=N82E16817371015
From the get go have been kinda unlucky with the build (deja vu from my own recent build) as he was sent a bunk psu. He choice to kinda skimp on the psu, but either way it should do its job and i dont suspect it to be the problem anymore.
the problem: Turn on the computer, all lights turn on, but nothing is displayed to the monitor(monitor is fine). Personally, it sounds like it is a graphics problem. But it also sounds like it could perhaps be a mobo problem. The mobo does NOT have onboard graphics so we cant bipass the card and check for sure. From your guys professional experience what do you guys think? He does have the thirty days return policy no questions asked and i suggested he just RMA them both. basically any ideas or suggestions you guys would have if this was your own machine.
Thanks in advance.
Thanks in advance.
