New Sound Card...How do I ensure onboard sound drivers removed??
TheNewGuy
326
Hiya folks...
My Santa Cruz soundcard is coming in this week, and when installing it, how do I ensure that my existing onboard sound drivers are removed properly? I know how to physically install the card, but I'm not 100% sure as to how to remove the existing drivers. I'm using an NEC Ready computer, with Win 98. Any info, or a how-to website would be greatly appreciated....
Thanks in advance...
Dave
bjc112
11,460
1. Disable on-board sound in your BIOS
2. If you have a sound card. go into device manager and remove it
3. Shut Down
4. Take off case
5. Remove the screw holding your sound card in. Wiggle up and down not siide to side to remove.
6. Boot up
7. install new drivers.
8 work out all of the bugs.
9. you are finsished!!!!
PM me if you need more help!!! :)
Paladinexe
307
I would suggest booting into Safe Mode and inspecting Device Manager. Items that do not show in normal Device Manager will sometimes be present in Safe Mode as history items.
If it is on-board sound, you might not be able to successfully remove them. I had this happen to me and I just clicked in the "Disable in this Hardware Profile" box it the Device Manager Properties for that item. This deactivated the onboard sound and my upgrade sound card worked fine.
I also had to do this in the same machine for video when I upgraded to a 3D accelerator.
bjc112
11,460
did it work??.. that should have been enough for you.. PM me if you need more.. you click the little lock in the upper right corner of my message..
TheNewGuy
326
It's coming in probably tomorrow, Tuesday at the latest....just trying to get as much info beforehand..if I have any questions during the process, I will definite PM you..
Dave
