tweakboy
That's classic tweakboy for you right there. :thumbsup:
Thanks brother...
everyone knows a seasonic is a good PSU.
Just that a rebranded seasonic these days is both cheaper and better making the brand name seasonic a not so good deal.
The EPS cable is longer now? Nice. I had no trouble routing the old EPS cable in my Define R3, so the new cable will definitely be easy to route in R4. And of course it's less bulky too which is nice.
I think Seasonic has addressed criticisms of their previous generation. They have longer cables, more PCI-E power connectors, more SATA power connectors, the ability to turn off the hybrid fanless mode of operation (having no fan running at low temps made some ppl edgy), tighter voltage regulation, and a longer warranty, and a lower price.
The newer versions are officially known as KM3 instead of KM (if you look closely at the supply label, it says KM3 where the 3 is superscript), but the ads for them still say KM.
Just for you I shutdown my computer, pulled out the cables, and checked the lengths of the motherboard and 8-pin power cables. The new ribbon style 8-pin cable is 3 1/4 inches longer than the older braid sheathed cable and the new ribbon motherboard cable is 3/4 of an inch longer.
I'm not sure what is the distance that you have to work with in your case but in my Lian Li PC-7FN case I could run the ribbon style 8-pin cable behind the plate that the motherboard is mounted on. The cable would barely reach but I think it would work. Originally when I installed the PSU that came with the braid sheathed style 8-pin cable I wanted to run it behind the plate but it wasn't long enough. I didn't have any luck finding an extension that would match the style of cable.
What I would like to know, are the connectors on these new cables still upside down when the psu is mounted on the bottom of the case?
