New ref machine for point determination for F@H
Does that mean that 500MHz Celerons will no longer be adequate to meet deadlines? I just about had one ready to put on F@H, but does the DC future of that machine now hang in the balance? 🙁
it should be usable,and pehaps more productive. it prob won't get any 160 pt WUs, should get mostly lower point Gromacs WUs.
The new points values are starting to roll in.
p212_villinURE212 was 160 now 135 ( -15%)
p724_Abeta21-43-amberGS was 49 now 63 ( +28%)
p563_BBA5_ext was 18 now 23 ( +27.7%)
It looks like they are stabilizing the points production, raising points on some work units and lowering points on others.
I wish I'd saved a full listing of the old points values.
So what does this mean for people with "slower" machines? We just get smaller things to crunch (worth less points)? Or is there no point in putting a pentium 866 ot something on this project?
I guess, the idea is that those of us with slower machines may still get plenty of Tinkers (at least that's what my Celeron gets most of the time), but they will be weighted to be worth more points, so the machines will end up being more "productive," in regard to score anyway.
So yes, there is certainly a point in having an 866MHz Pentium 3 on F@H. 🙂
There won't be any net difference for slower systems. Unless they change the deadlines, any PIII will continue to be an effective folder.
They had a problem where the projects that required the Tinker core paid fewer points than the projects that used the Gromacs core. It wouldn't surprise me if some people were deleting Tinker units when they got them and the science was suffering.
WOW, look at these Tinkers....
p693_L939_WT_Nat --- 244.00
P635_villin_c1_nat ---- 248.00
p696_L939_K12M_Raleigh ---- 235.00
p1110_L939_K12M_nat_min1 ---- 249.00
ripped from a post by Bruce over at the official forums:
If you are running a slow machine (one that cannot meet the standard deadlines) you should set the advanced configuration to a preference for GAH which will select unscheduled Tinker WUs. If it's a medium speed machine or better, the default preference for FAH will be fine.
All of the schedules just changed, along with the points, so all older recommendations for preference settings are probably obsolete. We need some time to see how the new points and the new schedules influence those recommendations.
