...on my PII 400 MHz Dell GX1. It powered up fine and I promptly disabled the onboard video board by entering system in the Windows 98 device manager. Rebooted fine and showed the "red X" over the motherboard video in the device mgr...so far, so good.
Now I get the supplied disk and follow the "ATI Easy Install" instructions. WHAM....it detects some problem and refuses to load completely. Next reboot the PC comes up in the Safe Mode and I promptly uninstall the ATI software thru the Control Panel. Now the machine does not boot into windows. Removed Radeon 9000 and re-enabled internal video...same result. The machine is now a useless brick that hangs on the Win98 startup screen. Tried to reinstall Win98 from startup disk, no improvement.
Looks like the 20G worth of files will need unloaded into another machine to do fresh Windows install from scratch.
Can I connect a Win98 drive with 20G of user files as the second drive on an NTFS XP machine in order to copy them. I'm assuming not.
Thanks for any feedback on how to rescue drive or files or how I screwed up.
