New Power Supply Continually Restarts PC
austin316
3,572
Ok, I was having major trouble booting up my computer and I felt (with the help of this board) that the problem was a faulty power supply. So I bought a new thermaltake 420w power supply, and hooked it up. The pc boots up perfectly, but then goes into the screen that windows xp did not load up properly. Do you want safe mode, last known good config, normal, etc. No matter which one I select, the pc just restarts and then goes to that screen again. That has never happened before the new power supply. What could be the problem?
helpmeout
540
Just off the top of my head-- Is everything securely plugged in? You didn't jar any cards-cables loose when installing the power supply, did you? I don't know much about PS, but I've read that different computers need certain voltages on certain rails? Don't know if that would effect Windows loading or not. Try booting with just the minimum connected.
austin316
3,572
Soyo Dragon + Mobo. (the old via 266 one)
512mb DDR PC2100 RAM
120 GB seagate drive
64MB GeForce MX 400 Video Card
all other cables for the dvd drive and so forth are removed.
tbalon
419
You may have to try booting from the XP cd and use the recovery console. It sounds like your current installation of XP is corrupted.
tbalon
419
" check your mobo's caps "
I think he means the capacitors on your motherboard....
look for signs of leaking bulging or discoloration, usually a sign that they are failing and as a result, your motherboard is toast...
austin316
3,572
More Info:
Athlon XP 1600+ CPU
The new powersupply is the $36 Thermaltake 420W
Over the summer my computer would continually lock up or get the blue screen that says to contact your hardware company. My drives sounded as if they were barely getting started, so as per replies on this board, I felt that my power supply was bad. I disconnected everything but the HD, and then my system worked decent until about a week ago. So then I bought the new power supply and started it, but it always goes to the screen that states if I would like safe mode, last know good config, etc. No matter what I select, the computer just restarts again. Can someone please help?!? And is this the correct forum to post in?
Also, my computer has 4 or so beeps on startup. Should I count exactly how many there are, is that important? thanks.
