IndyColtsFan
- Sep 22, 2007
- 33,655
- 687
- 126
Yep! that is mine as well
As others have said, the window needs to be sealed.
My house has casement (ie, swing out) windows and I bought the unit for my office, where temperatures can get into the 80s even with my central AC cooling the rest of the house into the low and mid 70s. At first, I built a foam-board insert for the window so I could remove the screen and replace it with the foam board insert which had a hole for the duct hose. That worked, but the foam was just too flimsy and a strong gust really affected it.
So for now, I ordered an extra screen and put my foam insert over the top of that. It is much sturdier but even still, there are gaps that probably need to be sealed. I'm going to build an aluminum frame and have a polycarbonate insert made for it and on the outside-facing side of the frame, I'll put foam tape so when I press it into place, it will hopefully seal everything well.
