New PC problem
mercuria
Hi all:
I just bought an AMD 64 3000+ with a MSI K8n neo Platinum, 1 GB Corsair ValueSelect DDR400 and GeXForce Radeon 9600Pro. I also got an LG 4160B DVD/RW and Seagate 160GB SATA HD.
After I put it all together, it keeps hutting down approximately 10 seconds after I start. The POST correctly detects the CPU, RAM, DVD drive and HDD.
After it shuts down, the power LED blinks slowly and I cannot restart it immediately.
Any ideas? Does this sound like overheating? I'm pretty sure I installed the cooling unit properly, though I didn't use my own paste (used the stuff that comes with the unit).
Thanks in advance
did u install SATA drivers??
try stripping it to the bare minimum...ie get rid of DVD drive lose one of your sticks of RAM then try again
have a look around the bios and there is usually a button or keypress to allow you to set everything to factory defaults... do you have a spare hard drive cos yours may be dead!
First of all, you have a Geforce Radeon 9600 Pro? It's either a Geforce or a Radeon, not both. Those are two different products from two different companies. That's like saying you have a "Pentium Athlon 64" or somethin...... anyway, it does sound like it could be a cooling problem. Check if the CPU fan is rotating normally. Also, get some proper thermal paste in there.
Sounds like your CPU is not properly mounted onto the Heatsink.
Check that there is thermal compound between them, or it hasn't come off and check there is a good tight connection between CPU and Heatsink.
ironique: typo - i meant GeXCube
everyone: thanks for your responses. yup - some new thermal paste did the trick.
the MSI NEO plat' board comes should come with the Diagnostic LED's on a back bracket.
They've saved me from a number of time saving troubleshooting episodes
