New pc parts - they will be compatible?
litwicki22
340
Hello.
I bought that parts, they will be compatible or there will be some problems? Can somebody confirm this:?Thank you.
motherboard Asus Sabertooth Z97 Mark2 :
https://uk.pcpartpicker.com/part/asus-motherboard-sabertoothz97mark2
cpu: I7 4790K
https://uk.pcpartpicker.com/part/intel-cpu-bx80646i74790k
ram: CML8GX3M2A1600C9W 2x 4gb Corsair
https://uk.pcpartpicker.com/part/corsair-memory-cml8gx3m2a1600c9w
g.card: Gigabyte Gtx 980 reference
https://uk.pcpartpicker.com/part/gigabyte-video-card-gvn980d54gdb
Psu: XFX 750W 80+ Bronze Certified Semi-Modular ATX
https://uk.pcpartpicker.com/part/xfx-power-supply-p1750xxxb9
III-V
678
You're good to go. This should have been posted in General Hardware, though.
Ken g6
Moderator
Dec 11, 1999
16,832
4,815
75
:awe: Everything looks good to me, assuming it all fits in your case. ("cabinet"?)
I would have bought cheaper parts, such as a 970 instead of a 980, but I'm a cheapskate. :p
litwicki22
340
But i dont have money for new case. I am using very old case Cooler Master Centurion 590 from 2008 year. So now my question. Can i use that case or should i buy necessary new case?
link:
http://www.coolermaster.com/case/mid-tower/centurion-590/
Here are pictures of that case ( this is not my pictures , but pictures of random people with the same case from internet ) :
Ken g6
Moderator
Dec 11, 1999
16,832
4,815
75
That case should be more than adequate, as long as you don't have as many drives as the last guy. ;) (Even then the video card could probably fit in somehow.) I was just worried you might have a micro-ATX case - or smaller!
Edit: But if money's tight, are you sure you don't want to step down to, say, an i5 4690K and a GTX 970? No point gaming at ultra-high settings if you can't afford to eat.
