You have a point, but I am looking for an aesthetically appealing case. Plus, it's at a great price. $69.99 AR AP. With that being said, will the graphics card I chose definitely fit in this case?PCPartPicker is fine for helping you organize your thoughts about a build. It's just not a substitute for doing your own research and comparison shopping.
If you're referring to the "I hate PCPartPicker" that's in a signature or two I wouldn't put too much stock in that.
Edit: Incidentally, the Nine Hundred wouldn't be my choice for a number of reasons. One, it's BigMcLargeHuge. If you really want that it's fine, but generally for the kind of machine you're building there's not a ton of benefit to it. It's designed to look "cool" if you like that flashy aesthetic and allow a lot of room for expansion and airflow - more airflow than you need for a build like yours. One thing it isn't going to do is be particularly quiet if that's of interest to you.
That said, more than anything else in the entire build the case comes down to personal preference, and it's the only part of the build you're going to see no matter where you are in the room. You should absolutely buy the one that appeals to you.
On a side note: Have you ever had issues with promo codes not working at checkout on Newegg? I've been trying to purchase this build for the last 12 hours and every time I get to check out, all of the promo codes are disabled. It says to call customer service, but it's Memorial Day, so they are closed.
