Hi all-
About 6 years ago I was a member here and learned to build my first rig with members' help. Since then I shamefully (lol) admit buying pre-built computers.
Now I'm back to wanting to build another computer and appreciate input on the hardware below. I'm looking to build a multi-tasking computer with gaming capabilities (more for operating my side companies). I will once again consider myself a newbie
Here are my requirements:
Cost: Around $650ish (not including 2 monitors - haven't decided which ones)
Purpose:
Able to multitask using Photoshop and Illustrator on one screen while running some applications on another screen (for web, SEO, marketing, online surfing, etc for small business). I used to be a big PC gamer(not as much today) however now mostly use my PS3 and Xbox 360. However I'd like the hardware to be able to handle today's games and not obsolete in 6 months.
Applications:
1) Photoshop and Illustrator (simultaneously) - Screen 1
2) Other applications (Office, Online surfing, SEO apps, etc)- Screen 2
3) Gaming (not as big a gamer as before but still would like to run today's games). I'll maybe spend a few hours(3-5) gaming a week
Now onto my initial hardware list (I'm perfectly fine with you making significant changes. I'm trying to keep it around $650-700 range(preferably $600). Any areas for cost savings would be ideal
Case: Antec Nine Hundred +EA650 power supply (http://www.newegg.com/Product/Produc...E16811129064)- $165 or should I go with case and a cheaper PSU?
Mobo and CPU (combo thru newegg):http://www.newegg.com/Product/ComboD...t=Combo.303840 - $~200 with rebates
Hard Drive: Newegg.com - Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - Internal Hard Drives - $55
Graphics card: (really unsure about what card to get): Sapphire 4860?
http://www.newegg.com/Product/Produc...82E16814102866 - $130
Power Supply: Is the one with the tower combo OK? Or better ones for cheaper?
RAM: OCZ Gold 4GB DDR3 (http://www.newegg.com/Product/Produc...82E16820227316) - $100
Heatsink: Newegg.com - Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler W/TX-2 - CPU Fans & Heatsinks - $40
Thanks much for your time and help!
Purpose:
Applications:
