- Aug 18, 2000
- 492
- 0
- 71
<FONT size=2>
I just received a biostar m6vlq that i bought from newegg.com. I installed it inside a case, inserted my celeron 466MHZ, attached a heatsink installed a stick of pc100 322 64MB ram, plugged in the power to the motherboard, and plugged in my monitor and keyboard.
I tried to boot it, the fans inside the case spun and the case lights turned on, but there was no beep, and the monitor didnt turn on. Usually this seems like its a memory problem, so i tried another stick of pc100 322 64MB ram, and i had the same results. I then tried a stick of 32MB pc66 ram and again same results. I've tried different slots, resetting the cmos jumper, even trying a different celeron 466MHz processor, but no change. The only other thing i could think that would be a problem is i dont have my heatsink's fan plugged into the motherboard header, it uses a regular 4 pin molex. Before i go splicing wires to make my fan plug into the header, are there any other solutions that i'm not thinking of/is there anything special about this motherboard?
thanks for your time and help.</FONT>
