New Monitor - slight problem
SamS
49
I just got a brand new NEC FP1350X 22" totally flat screen monitor! And it rocks! The only problem is that I see some slight ghosting on the screen (multiple images). I have been told that this is caused by either a bad connection to the montior or a low quality analog cable. I just bought the best cable I could find (expensive too) and it only improved the image slightly. There is still some ghosting.
This is a brand new monitor.. I a have the latest drivers from NEC's site. I am running at 1920 x 1440 @ 76Hz.. but I have tried all other resolutions including 800x600 etc.. and the ghosting is still the same.
I have a Geforce2 GTS w/ 32mb ram.
Any ideas?
Asif
1,276
a ups too close to the monitor will do freaky thing as well
MrCoyote
I just bought a NEC FP955 19", and am getting slight ghosting as well. This is actually my second FP955, as the first had a bad phosphor dot, so I exchanged it. I didn't notice ghosting on the first monitor but I didn't look to close at it.
I thought my second monitor looked okay, until I started to notice some ghosting of some text.
My ghosting only goes away by setting the resolution to 640x480. Anything higher, and I get ghosting which appears to the right of any text. I tried another video card, but still get ghosting. Damn, I'd hate to send back this monitor again.
Could it be caused by the video cable included? You would think NEC would include a good quality cable with their professional monitors.
