Below are the pre-req answers
1. Upgrade from a 7 year old Core Duo rig, primarily for gaming.
2. About $1500 give or take
3. US
4. N/A
5. See below
6. Nope
7. Default usually say oc but I never do
not since the Celeron 300a days
8. 1920 x 1080
9. In the next month? Maybe this weekend?
10. Windows 7
So based on the mid range post and some other threads this is what I came up with so far... Feel free to give opinions and answer any questions I have it is much appreciated
CPU: Intel Core i7-4790K
Mobo: Not sure got a ton of a questions...
The socket is LGA 1150. The chipset is the Z87 but there was a refresh of the chipset to Z97. Is there any practical use for the features of the Z97? Like Haswell Refresh CPUs, SATA Express. Prefer Asus mobos just in case anything goes wrong I can RMA instead of the company like Epox no longer existing.
Memory: G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Any other suggestions?
Hard drives: definitely SSD that will be the biggest change, not sure if there is a preferred preference for the Samsung Pro vs EVO or the Crucial one like the MX100 or is it all relative? Thinking of getting two drives one for os (256) and another for everything else (512)
GPU: Nvidia GTX 970 believe some suggested the Gigabyte one. Any particular GTX 970 people like?
Optical drive: SAMSUNG DVD Burner 24X from mid range guide
PS: SeaSonic M12II 620 Bronze 620W from mid range guide
Case: Love my Praetorian aluminum case too bad they don't make those any more. I think having a removable mobo tray is easier. Any suggestions other than the ones from the mid range guide?
Lastly for running a higher resolution than 1920 x 1080 are there any suggestions for bigger monitors? Currently using an Asus VW246H monitor.
3. US
4. N/A
5. See below
6. Nope
8. 1920 x 1080
10. Windows 7
