New joystick problem....
hotboyz012345
55
Hi, i m new to joy stick and even it's my first chance and have a problem that in game, the camera and player runs round and round and i can't stop the player and when i set the controls it's automatically sets the option z and I don't know what is z. i guess it's an axis but correct me if I wrong .
Joystick name is genius max fighter f-31u vibration.
Thanks.
oynaz
2,449
You probably need to calibrate it. There is an option for this in the Control Panel.
hotboyz012345
55
I done all that thing and when i reinstall the driver it works right except in darksiders game.it give me the problem in that game only.
Fardringle
9,200
765
If it works with everything except the Darksiders game, then its a problem with the game itself (or there may be separate joystick calibration tools inside the game). Either way, I'd recommend asking on the Darksiders forum since you're having a problem with the game.
hotboyz012345
55
but when i try to set the controls in pcsx2 software control then it shows that the y axis is always selected or set in the software how can i disable the y axis to close that problem
