Here's an easy project for anyone....a completely de-coupled case fan mount. The mounts are electrical boxes, available in many sizes, no cutting required, at any hardware store. That's an 80mm fan in the photos.
Find a piece of foam, cut it slightly larger than the box. Cut a hole in the center of the foam slightly smaller than the fan. Insert the fan in the foam, and stuff the the whole assy into the box.
These boxes can be mounted to the case using the little threaded tabs and supplied screws. (you'd drill two holes in the case) Or you could turn the box around and mount it using the two small slots.
Completely suspending your case fan in foam will definately cut down on the noise/vibrations. I think this is an easier and more effective solution than rubber grommets.....none of the mount screws actually touch the fan. The box cost less than $2. FWIW...the finished box in the pictures fits a Lanboy perfectly.
I hope this is a new idea.I've never seen it used anywhere....
Part two...
Ok...here's a new invention. I'm sure someone will cash in on this. But it's so easy to make, cost less than $5 in parts, I don't see why anyone would buy it pre-made.
You can stack these electrical boxes using the little tabs....absolutely no cutting. This is what I did to the first box. In the lower box I added a filter, a cut-out piece of a high-performance furnace filter. The pleats are necessary to give enough surface area to prevent too much restriction. Even then, my temps went up 2-3C.....ok for me as this setup is running cool.
If you want, you can buy a top with a cut-out hole to attach a duct.....I'm not using it this way. I covered the two boxes with CompUSA acoustic foam...seals the cracks between the boxes and provides some quieting.
This new setup mounts the same way as one box...two screws through the back into the two little tabs.
To change the filter, my SFF computer hinges apart, the plastic side unsnaps, and I remove the two screws....easy. This setup quieted my computer to the point I'm now hearing the Maxtor only...damn.That computer in the pictures is running off this one intake fan only without any exhaust fan. The P/S is external.
Feel free to make your own.....just give me credit for the design. More pictures...
http://photos.yahoo.com/bc/bluefron...order=&.view=t&.done=http://photos.yahoo.com/
Fan/Filter holder
Part two...
Fan/Filter holder
