Let's celebrate the six month anniversary of OCZ's press release regarding new firmware that "Supports 2xnm NAND Flash and Increases Performance of Indilinx Controllers by up to 500%" Do you remember where you were on the day of the announcement?
Administrator IdontcareDo not use our Forums to post any material, or links to any material, which is knowingly false and/or defamatory, inaccurate, abusive, vulgar, hateful, harassing, obscene, profane, sexually oriented, threatening, invasive of a person's privacy, or otherwise violative of any law. Special exception to the restrictions on vulgarity and profanity are granted ONLY in the social forums.
AnandTech Forum Guidelines
The revolutionary new Arowana FTL enhances performance of Indilinx controllers with HyperQueuing, which significantly increases sequential write speeds and random IOPS over the previous generation FTL
Good luck with that.and hacked the firmware from the 710 over
Do you really think that IMFT would have customers like OCZ, Corsair and the likes if they were shipping them vastly inferior NAND to what they use in their 320? The fact that MLC-HET only lasts 3 months after use and not 12 says straight away that it is not just 'cherry picked' regular NAND.(other companies buying intel nand = B grade junk)
Yeah mate send it over. I would like to read it. The LPM bugs you mention, do they effect the H67 range as well as P67 and Z68?
And I doubt your proposal of hacking the firmware in such a way is possible. Disabling some function calls, changing return values and so on - sure that's easy. But pretty much changing the inner workings of a complex code with only the assembly (and then that's no detailed documented asm like for x86,..) available seems pretty impossible.
you essentially sacrifice lifespan with max iops
