New Home theater sound help.
Andres3605
927
I just bought a 37" LCD HDTV and was looking into getting a sorround system to go along with it, I'm in no way audiophile or have large amounts of cash to spend in high end equipment.
At the moment i have my PS 3 and my HDTV Direct tv box connected with HDMI Cables, don't mind using components if i have to, i was looking at several receivers and the possibility of starting with just a 2.1 setup and buy more speakers as my money allows me to.
This is the receiver i was looking at this receiver Onkyo TX-SR505S and some Polk R150 speakers to start, but i would like some advice, im not really that literate iin regards of Dolby/DTS/PCM and such.
I would like some receiver / speaker suggestions with a thigh budged in mind, thanks.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
You can keep the video hooked up directly to the TV and just send audio to the receiver, so no need to worry about getting a receiver that can't handle all your video sources. On the other hand HDMI is the only want to get HD audio formats off your PS3 from Blu-ray discs, but that's no bid deal in the grand scheme of things.
I think what you have picked out would be a decent starter system. The receiver is pretty good so you could certainly grow with that.
For Dolby / DTS / PCM, the Onkyo 505 will handle everything you need it to except for HD audio formats (unless you get a player with multichannel analog output). For a budget system, that receiver will handle everything you need it to. To move up to a receiver that can do multichannel PCM over HDMI (or decode them from a bitstream output from a player), you'd need to spend ~$400 on just the receiver. DD and DTS are going to sound great already, so no need to worry about that at this point.
