New guy with power supply question
new22003
64
Hi guys I?m a noob. I am just getting my feet wet working on a hand me down pc with hand me down parts. I have upgraded things like graphics cards, memory, and optical drives before but that?s really about as far as I have gone. I am no expert.
I recently received an older HP Pavilion a320n pc with the specs as follows.
Athlon 2800+
1 gig ram
120 gig hd
a7n8x-la motherboard (HP OEM)
The comp runs great but is less than stellar in the graphics department (currently Radeon 9000). I was also given a Radeon x800xt platinum AGP by my brother which I imagine would really pick things up a bit. I know it still wont be the best thing in the world (some day I will have a 2 gig, pcie/sli, 4000+) but its mostly free stuff and I believe it will be a good learning experience.
My problem is this. The power supply in the case right now is the factory unit from hp and is only 250 watts (bestec atx-250-12z). I know this wont support the x800xt. What do I need to look for in a good power supply? Do I have to worry about any fitment in the case or running too much power to certain devices? I know quality is very important on a power supply do you experts have any recommendations?
Thank yo very much for any assistance.
GalvanizedYankee
6,986
Welcome new guy. Working with a proprietary case and hardware is a royal pita..OK.
Here's your stock PSU. It is standard ATX size & pinouts on the connections. I'm not sure if you have an off/on switch at the rear of the PSU in your case now. Sometimes a replacement PSU with a switch can cause difficulties.
http://www.power-on.com/atx12v250bt.html
If your set-up can accept a PSU with a downward facing 120mm fan, I highly reccomend you get this bad-boy http://www.ewiz.com/detail.php?name=PS-E5140GH specs at http://www.enhanceusa.com/ A nice 80Plus cert at http://www.80plus.org/
The 24 pin splits for 20 pin application and there will be some connections you won't use on your present system. But this is a VG PSU for $57. You will be able to find something OK in the $40 range but this is a good deal on a very efficient unit.
...Galvanized
Geiser34
98
Hey, I actually have an a230n also, and I was wondering about a new power supply, thanks Galvanized, I ordered one.
:thumbsup:
jackschmittusa
5,972
There is no need to worry about a psu suppling too much power to any devices. Psus don't push power to anything, the device simply draws what it needs.
new22003
64
Thanks so much for your quick reply. You helped me out quite a bit. Just needed a little confidence witht he swap. Have a great day.
